Cisco 3560 and Tsunami Wifi Devices
Answered Question
Mar 17th, 2009
Everyone, here is my issue. I have two buildings that we are trying to connect via two Tusnami Wifi devices. In my testing I am having troubles getting the two devices to transmit data or I should say that they see each other but no data is passed to my switches. I have attached a simple PDF so show my test enviroment. Basically I have a 3560 switch and a base tx/rx unit and another 3560 switch and satellite tx/rx unit. The two wifi devices will see each other an perform a link test between the two with great signal. From each side I can ping the IP I manually put on each wifi from my laptop, but cannot ping the other switch from either side. I have the devices attached to trunk ports on each switch. Has anyone had any experience with these devices. Thanks in advance.
Correct Answer by Giuseppe Larosa about 8 years 2 months ago
Hello Ronald,
start to verify the native vlan settings on both sides
sh int fasx/y switchport
the device data sheet declares they are able to carry vlan tagged frames (802.1Q)
see
http://www.proxim.com/downloads/products/mp16/DS_0806_MP16_3500_A4HR.pdf
a problem with native vlan mismatch could cause ip connectivity issues
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 03/17/2009 - 06:10
  • Hall of Fame,
    Founding Member
Hello Ronald,
see
Hope to help
Giuseppe
