Require help in NTP Config
Answered Question
Mar 17th, 2009
Can somebody tell me how to configure NTP.Which router i can configure as a NTP server for sync with cleint.
Pls brief me the config on both ntp server and cleint.
Correct Answer by Edison Ortiz about 8 years 3 months ago
Cisco routers aren't the ideal NTP servers. I suggest syncing your routers against a reliable internet NTP server. For more information on NTP, please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_basic_sys_manage_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001170
HTH,
__
Edison.
Overall Rating: 4 (1 ratings)
Correct Answer
Edison Ortiz Tue, 03/17/2009 - 07:32
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
Leo Laohoo Tue, 03/17/2009 - 15:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Edison's right. Synchronise your router(s) with a authorized time server based on your geographical location. If you are in England, don't synchronize with a time server in China, for example.
A list of the Simple Network Time Protocol (SNTP) time servers that are available on the Internet
http://support.microsoft.com/kb/262680
Leo Laohoo Tue, 03/17/2009 - 18:41
  • Hall of Fame,
    2017 LAN, Wireless
Whoopsie. True. But you can use the same (S)NTP servers as NTP.
