cnf-files error
Mar 17th, 2009
i want to configure an old router 1760 as ccme . But when i want to create cnf-files i have this error :
"cannot currently create files. Please verify CME Configuration"
Do you have an idea ?
Guillaume
david-lima Tue, 03/17/2009 - 06:26
  • Bronze, 100 points or more
Hi Guillaume, did you configure max-ephones, max-dn under, ip source-address telephony services?
What IOS version are you running?
If is possible, share you CCME config
Best regards
David
c.marcillat Tue, 03/17/2009 - 06:35
The version is 1700-spservicesk9-mz.124-15.T8.
I send the conf asap.
thank
c.marcillat Tue, 03/17/2009 - 07:01
the configuration :
version 12.4
service password-encryption
hostname Arketeam
boot-start-marker
boot system flash c1700-spservicesk9-mz.124-15.T8.bin
boot-end-marker
enable secret 5 xxx
aaa new-model
aaa session-id common
clock timezone UTP+1 1
clock summer-time UTP+1 recurring last Sun Mar 2:00 last Sun Oct 3:00
tdm clock bri-auto
voice-card 3
ip cef
no ip dhcp use vrf connected
ip dhcp pool Tel
network 172.16.99.0 255.255.255.0
option 150 ip 172.16.99.254
default-router 172.16.99.254
isdn switch-type basic-net3
voice call carrier capacity active
voice rtp send-recv
voice service voip
modem passthrough nse codec g711alaw
username xxx privilege 15 secret 5 xxxxx
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.1.254 255.255.255.0
interface FastEthernet0/0.99
encapsulation dot1Q 99
ip address 172.16.99.254 255.255.255.0
interface BRI3/0
no ip address
isdn timer T310 60000
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
interface BRI3/1
no ip address
isdn static-tei 0
ip forward-protocol nd
no ip http server
no ip http secure-server
tftp-server flash:ATA030100SCCP040211A.zup
tftp-server flash:P00308000400.bin
control-plane
voice-port 3/0
compand-type a-law
cptone FR
voice-port 3/1
compand-type a-law
cptone FR
dial-peer voice 1 pots
preference 1
destination-pattern 0T
direct-inward-dial
port 3/0
dial-peer voice 2 pots
preference 2
direct-inward-dial
port 3/1
telephony-service
load 7960-7940 P00308000400
max-ephones 10
max-dn 150
ip source-address 172.16.99.254 port 2000
system message xxxxx
cnf-file location flash:
cnf-file perphone
time-format 24
date-format dd-mm-yy
max-conferences 4 gain -6
call-forward pattern .T
moh music-on-hold.au
transfer-system full-consult
transfer-pattern .T
line con 0
line aux 0
line vty 0 4
end
david-lima Tue, 03/17/2009 - 07:49
Hi, is it a new configuration?
If is possible, try this:
no cnf-file location flash:
And create cnf files again
create cnf-files
Best regards
David
