Redistributing vs. advertising
Mar 17th, 2009
I've read a lot of Cisco documentation and have worked through the relevant sections of Jeff Doyle's book, but I'm still having difficulty with this topic. Can somebody give a "25 words or less" sort of explanation of the difference between "redistributing via" and "advertised by"?
Giuseppe Larosa Tue, 03/17/2009 - 07:18
  • Hall of Fame,
    Founding Member
Hello George,
if you don't see the line advertised by the route is not actually propagated in the destination routing protocol
example from our network
sh ip route 10.34.22.144
Routing entry for 10.34.22.144/28
Known via "static", distance 1, metric 0 (connected)
Redistributing via isis
Advertised by isis metric-type internal level-1-2 route-map red_stat
Routing Descriptor Blocks:
* directly connected, via Tunnel49
Route metric is 0, traffic share count is 1
redistributing via IS-IS means there is a redistribute static inside IS-IS process
the line advertised by means that is really advertised
Hope to help
Giuseppe
Edison Ortiz Tue, 03/17/2009 - 07:21
  • Hall of Fame,
    Founding Member
You will only see those 2 entries on a route when the router is running 2 or more routing protocols.
If you see the entry redistributing via, it means that route is running within that routing protocol and it's eligible for redistribution into another routing protocol.
If you see the line above along with advertised by, it means the route has be redistributed and it's currently being advertised. It will also show the routing protocols where this route exists.
HTH,
__
Edison.
Giuseppe Larosa Tue, 03/17/2009 - 07:30
  • Hall of Fame,
    Founding Member
Hello Edison,
I confirm the following is a subnet of another building in the same campus
sh ip route 10.103.70.0
Routing entry for 10.103.70.0/24
Known via "isis", distance 115, metric 30, type level-1
Last update from 10.82.130.149 on TenGigabitEthernet3/6, 7w0d ago
* 10.82.130.149, from 10.80.0.116, via TenGigabitEthernet3/6
Route metric is 30, traffic share count is 1
Thanks for your correction I was thinking only of the case when you want to check if a redistributed route is really advertised in the destination protocol
Best Regards
Giuseppe
Edison Ortiz Tue, 03/17/2009 - 07:34
  • Hall of Fame,
    Founding Member
Giuseppe,
No problem :)
The OP question is one of those tricky question I've seen on interviews and the naming used on the output is quite misleading.
__
Edison.
adamclarkuk_2 Tue, 03/17/2009 - 07:22
  • Silver, 250 points or more
[Edit]
Misread the question
Redistributing is injecting a route/prefix from another source be it from a static route or another protocol, advertising a route is originating that route from the protocol itself. It is always better to source than to redistribute if possible.
Example
BGP
I have a static route on my router pointing to Null 0
ip route 192.168.1.1 255.255.255.255 Null/0
I can pass this into the BGP RIB via 2 methods, redistribution or originating the route
redistro
router bgp 65535
redistribute static subnets
Originate
router bgp
network 192.168.1.1 mask 255.255.255.255
Edison Ortiz Tue, 03/17/2009 - 07:40
  • Hall of Fame,
    Founding Member
Adam,
That's not the answer on this scenario :)
adamclarkuk_2 Tue, 03/17/2009 - 07:42
Hi ediortiz
yeah sorry, I did add an edit, I misread the question ;-s
lamav Tue, 03/17/2009 - 07:26
  • Blue, 1500 points or more
Give me the relevant pages from the DOyle book, please, so I can read it for myself.
gkuzmowycz Tue, 03/17/2009 - 08:11
Thanks to all for replying. Didn't know I'd spark such a discussion.
To Edison: this isn't/wasn't from an interview, I'm just trying to understand. As you noted, the output from sh ip route isn't as clear as I'd like.
To Adam: I know what redistribution is -- this was a bit more involved, as I'll show below.
To Victor: Jeff Doyle's Vol 1 Chapter 11 (page 694 ff) is about redistribution, but my reason for posting here was that it didn't actually answer the distinction.
What I have, edited for brevity, is this
router eigrp 1
redistribute connected
network 172.16.205.0 0.0.0.255
network 172.16.206.0 0.0.0.255
network 172.18.0.0
no auto-summary
router bgp 65000
bgp log-neighbor-changes
neighbor nn.nn.nn.nn remote-as xxx
address-family ipv4
redistribute eigrp 1
neighbor nn.nn.nn.nn activate
no auto-summary
no synchronization
which gives me an actual view like this
VG3-3845#sh ip route 172.28.0.0
Routing entry for 172.28.0.0/16
Known via "eigrp 1", distance 120, metric 178944, type internal
Redistributing via eigrp 1, bgp 65000
Advertised by bgp 65000
Last update from 172.16.205.1 on GigabitEthernet0/0, 3w2d ago
Note that 172.28.0.0/16 is not "originated by" either routing process and is not directly connected. It is learned via EIGRP from one of this router's neighbors. That fact, to me, explains why it is "redistributed via" the EIGRP 1 process. The "redistribute eigrp" in the BGP process explains why it is "redistributed via" the BGP 65000 process. What I was trying to understand was why it is only "advertised by" the BGP process and not by the EIGRP process.
Edison Ortiz Tue, 03/17/2009 - 08:21
  • Hall of Fame,
    Founding Member
George,
I didn't mean to imply you saw the question on an interview. I said "I've seen that question in some interviews" :)
BTW, I re-read my previous reply and the redistributing via will list the routing protocols that are currently advertising the route, NOT the advertised by entry.
The naming convention used is quite confusing and every time I think about it, I have to think backwards.
Here is a native EIGRP route that is being redistributed into OSPF.
R2#sh ip route 32.0.0.0
Routing entry for 32.0.0.0/8
Known via "eigrp 1", distance 90, metric 156160, type internal
Redistributing via ospf 1, eigrp 1
Advertised by ospf 1 subnets
Notice the router is telling us that the route is on both databases with the redistributing via but the router is only advertising the route as OSPF route since it received this route as EIGRP from a neighbor.
In your case 172.28.0.0/16 was learned via EIGRP. The route is on both EIGRP and BGP and it's currently advertising it via BGP.
__
Edison.
gkuzmowycz Tue, 03/17/2009 - 09:12
Edison:
I really do appreciate your responses, but I guess I'm still not understanding. Maybe I'm just dense. But "advertising by" doesn't make much sense to me. Going back to my config, for instance, the only router which has 172.28.0.0/16 as a connected interface has the following config
router eigrp 1
network 172.28.0.0
network 172.29.0.0
auto-summary
router rip
network 172.28.0.0
network 172.29.0.0
Yet it shows me this
R2#sh ip route 172.28.0.0
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 1, rip
Advertised by rip
What information is "Advertised by rip" giving me? It's a directly connected network, and it's being "originated", as far as I understand, by both routing processes.
Edison Ortiz Tue, 03/17/2009 - 09:24
  • Hall of Fame,
    Founding Member
George,
Here is what I get when having the same route on both networks introduced into that routing protocol via the network command:
R2#sh ip route 22.2.2.2
Routing entry for 22.2.2.0/24
* directly connected, via Loopback2
Now, this is what I get when introduced into that routing protocol via redistribution:
R2#sh ip route 23.3.3.3
Routing entry for 23.3.3.0/24
Advertised by ospf 1 subnets route-map CONNECTED-TO-IGP
eigrp 1 metric 1 1 1 1 1 route-map CONNECTED-TO-IGP
* directly connected, via Loopback3
Now, you have come to a corner case scenario. In your case, 172.28.0.0/16 is on both EIGRP and RIP databases but EIGRP has a lower AD so it treats EIGRP as the primary routing protocol and RIP as the secondary routing protocol and they are both using the same link/neighbor, so in essence, you are bringing an EIGRP route into RIP and advertising it by RIP.
What are your neighbors, RIP or OSPF?
gkuzmowycz Thu, 03/19/2009 - 13:04
Sorry, I didn't see the question in your last line. This router's neighbor (it has only one) is running both EIGRP and RIP. No OSPF.
Things have gotten murkier, though. I have removed the RIP process from the router in question by removing all the network statements from "router rip" and then saying "no router rip". If I say sh ip route rip or sh ip rip database I get nothing. Yet there's this
Advertised by rip
* directly connected, via TokenRing1/0
So I'm "advertising by" a routing protocol that this router is not running. This is not helping me understand.
Edison Ortiz Fri, 03/20/2009 - 07:38
  • Hall of Fame,
    Founding Member
How long did you wait?
Try clearing the route table.
__
Edison.
gkuzmowycz Fri, 03/20/2009 - 08:25
It had been over 24 hours.
That fixed it. Thanks.
milan.kulik Fri, 03/20/2009 - 04:02
  • Red, 2250 points or more
Hi Edison,
IMHO, the explanantion might be:
The "Advertising by" line is showing the particular command used for the redistribution from one routing protocol to the other.
I.e., in your case, you probably use:
router ospf 1
redistribute eigrp 1 metric 1 1 1 1 1 route-map CONNECTED-TO-IGP
and
router eigrp 1
redistribute ospf 1 subnets route-map CONNECTED-TO-IGP
aren't you?
I can't explain the previous example:
"R2#sh ip route 172.28.0.0
Advertised by rip"
It looks like a RIP route redistributed into EIGRP by "redistribute rip" command.
I can't remember: isn't there RIP redistribution to EIGRP automatic in IOS?
BR,
Milan
Edison Ortiz Fri, 03/20/2009 - 07:41
  • Hall of Fame,
    Founding Member
router ospf 1
and
router eigrp 1
aren't you?
Yes.
No.
__
Edison
