1841 router with WIC 1ADSL
Mar 17th, 2009
Pros,
The new 1841 router with the default image c1841-ipbase-mz.124-6.XE3.bin loaded not coming up with ADSL WIC installed on any slot of the router. It keeps on rebooting. Pls see the attached file for the boot sequence.
Even after i loaded with the new image c1841-ipbasek9-mz.124-24.T.bin, the same problem.
What is the work around to solve this issue?
swami
Giuseppe Larosa Tue, 03/17/2009 - 07:35
Hello Arumugasamy,
you need to upgrade to an IOS image that supports the ADSL WIC
try with
c1841-ipbasek9-mz.124-15.T8.bin
that FN declares support it
see
www.cisco.com/go/fn
Hope to help
Giuseppe
thiru.vel10 Tue, 03/17/2009 - 22:53
Try to upgreade the IOS to advanceservice 12.4.This image will support the ADSL card with advance security " IOS filter "
arumugasamy Wed, 03/18/2009 - 05:02
I tried 4 ios images. This card i tried with another router with the same problem. But when i used another WIC adsl with this router, it is working. So I believe that the WIC is defective.
Let me wait and update you
swami
Leo Laohoo Wed, 03/18/2009 - 15:42
With the suspected faulted WIC card, during the bootup, are there any error messages?
