audio in one way from cme's phone to the pstn (using a E1)
Mar 17th, 2009
hi there is one way audio in the calls generated or originated from the cme's phone, the physical connection is through an E1, and this problem also happens with a FXO port. I think that something is happening with dsp, what do you think?
i sincronized the wic where the E1 is located with the internal clock of the router, and the show voice dsp voice, i see there are a lot of resources.
thanks
david-lima Tue, 03/17/2009 - 13:19
  • Bronze, 100 points or more
Hi, verify if "h323-gateway voip bind srcaddr ip address" in configured on the interface you are using for signaling in your voice gateway, also vevrify if you have configured this command: "voice rtp send-recv" in your router.
Hope this help
David
