site to site vpn
Mar 17th, 2009
Can we setup site to site vpn using Broadband internet connection. we get different Public address on our Nortel every day . with this situation can anyway we can setup a site to site vpn with other side cisco PIX.
If possible what is the needed configuration needed in both side.
Any response is highly appreciated.
Overall Rating: 5 (1 ratings)
ex_pmadayag Tue, 03/24/2009 - 08:16
hi,
Yes, for as long as the pix has a static wan ip address, you can setup vpn site to site even if the other peer has a dynamic ip.
You just need to configure the pix firewall to accept dynamic vpn connections.
check the ff links:
>> if you are using pix 6.3 and lower
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a0080094680.shtml
>> if you are using pix ver 7
https://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805733df.shtml
Hope this helps.
sbantz Thu, 03/26/2009 - 08:45
I wish they had bolded the necessary configuration changes in the version 7 document. The comments and boldfaced type in the ver 6.3 instructions was easy to see.
