assign a private line to n IP phone
Answered Question
Mar 17th, 2009
Dears, is there anyway that i can use on callManager 4.3 to assign a private line to a specific extension so that extension only can dial outside numbers through this line?
There is any similar way to configure it on cme by associating a directory number with a foreign exchange office (FXO) port. Is there any similar way to configure it on callmanager 4.3?
Correct Answer by Jaime Valencia about 8 years 1 month ago
no, you can create a route pattern and bind it to the FXO. but there is no real equivalent of 1 button - 1 fxo
on FXO config attendant DN to that line
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 03/17/2009 - 08:21
  • Cisco Employee,
  • Hall of Fame,
    2011
very simple, use a CSS that only reaches route patterns to PSTN
if you don't want anyone calling the line create a special partition and do not add it to any CSS
java
Mustafa Al Housami Tue, 03/17/2009 - 08:44
there is no config similar to the trunk that is configured on cme that associates the dn with the fxo port?
Correct Answer
Jaime Valencia Tue, 03/17/2009 - 08:49
  • Cisco Employee,
  • Hall of Fame,
    2011
java
