Doing NAT for VPN clients going over L2L tunnel
Answered Question
Mar 17th, 2009
Hi.I have the following situation in my network.We have a need for users who connect to our site with VPN clients to connect to another site via a L2L tunnel. The problem is that I need to NAT the addresses from the VPN client pool to another range before going over the L2L tunnel because on the other side we have overlapping networks.
I have been trying to do NAT along the following lines with little success:
ACL for NAT of VPN pool:
access-list TEST extended permit ip 192.168.253.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list TEST extended permit ip 192.168.253.0 255.255.255.0 192.168.5.0 255.255.255.0
NAT:
global (outside) 15 172.20.105.1-172.20.105.254
nat (inside) 15 access-list TEST
CRYPTO ACL:
access-list RO extended permit ip LAN 255.255.0.0 192.168.0.0 255.255.255.0
access-list RO extended permit ip LAN 255.255.0.0 192.168.5.0 255.255.255.0
access-list RO extended permit ip 172.20.105.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list RO extended permit ip 172.20.105.0 255.255.255.0 192.168.5.0 255.255.255.0
same-security-traffic permit intra-interface
Am I missing something here? Can something like this be done at all?
Thanks in advance for any help.
We are using ASA 5510 with software version 8.0(3)6.
Correct Answer by acomiskey about 7 years 10 months ago
You need to nat on the outside, not the inside.
nat (outside) 15 access-list TEST
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Tue, 03/17/2009 - 08:56
IgorHamzic Tue, 03/17/2009 - 09:19
Thanks.I did it already.I realized with the help of a friend I was using the wrong logic for the NAT and changed it.
Now I can get ping across the L2L tunnel from the VPN client without fail.
Thanks for the reply though.
