LMS 2.6 /Under Solaris - Data collection
Mar 17th, 2009
Under Campus Manager , the data collection has been launched but never ending (since January ).
The campus manager version is a 4.0.10 one. Does someone know which process has been invoked when data collection is running ?
Is there a PDSHOW batch like in windows which could be analyzed ?
I had doing a test , even if it's in window, but when the PDSHOW has been running, the output has never showed the process associated with Data Collection ( started from the GUI).
Joe Clarke Tue, 03/17/2009 - 10:13
Data Collection is handled by ANIServer. ANIServer should always be running, however, even when Data Collection is not. The only safe way to force a Data Collection to stop is to restart dmgtd. The pdshow command on Solaris can be found in /opt/CSCOpx/bin.
richard.tetu Wed, 03/18/2009 - 09:43
The customer has did a restart dmgtd , but the CampusManager is showing that the the DataCollection si still running form January.
It could be a bug or a process blocked....
Have someone have an idea , has the pdshow don't showing anything relevant ?
Joe Clarke Wed, 03/18/2009 - 10:31
You haven't posted a pdshow output. If the customer really restart dmgtd, then Data Collection should not still show running. Where are they seeing this? A screenshot of the problem would help.
richard.tetu Thu, 03/19/2009 - 08:20
I have posted : the pdshow and an a screenshot of the CM's GUI.
I have added the ani.zip ( who is the zip og the ani.log)as i saw a ANI.exception base .
Joe Clarke Thu, 03/19/2009 - 10:39
First, the time shown is the last time Data Collection completed, not when it was last started. Second, Daemon Manager was not restarted since February 11. I also see a database error in the ani.log on 3/9.
I suggest you actually restart Daemon Manager to get ANIServer and ANIDbEngine to resync. If the database errors continue, you may need to reinitialize the ANI database.
