Reverse Telnet: Aux/Console
Carlo Zaina
Hi.
Router R1 has some trouble during the boot, so i wish to connect via R2's Auxiliary port to R1's console port.
What's the configuration for the Aux port on R2?
So far i implemented this:
line aux 0
modem InOut
transport input all
transport output all
#show line
5 AUX 9600/9600 - inout
If i telnet to R2's Loopback ip address with port number 2005 i get an "open" and nothing else.
Also, for the connection, what kind of cable do i need? I read around "flat crossover cable": an ethernet cross cable might work?
Thank you
8 Replies 8
paolo bevilacqua
No, ethernet crossover will not work. You need the "flat crossover cable" shipped with every router.
Honestly, i have seen only rollover cables, ethernet cables and console cables shipped with the routers.
I was trying to figure out the pin layout...
Rollover cable is what we're talking about. 1-8 2-7 3-6 4-5.
Perfect.
Pin Layout:
1 2 3 4 5 6 7 8
8 7 6 5 4 3 2 1
So, in order to be able to connect from the R2's Auxiliary port to the R1's Console port, what else should i do?
Nothing else. Remember to rate useful posts with the scrollbox below.
Well, i am still unable to connect.
R1's Config
line aux 0
modem InOut
transport preferred telnet
transport input all
#show line
* 1 1 AUX 9600/9600 - inout
#sh ip interface brief
Loopback100 192.168.254.1 YES manual up up
(C1841-IPBASEK9-M), Version 12.4(20)T1
R2's Config
line con 0
logging synchronous
However:
R1#telnet 192.168.254.1 1
Trying 192.168.254.1, 1 ...
% Connection refused by remote host
Any further tip?
You should connect to port 2005.
Beside that, sometime the line remains taken from previous use, do "clear line 5" on R1.
Suddenly, after the 4th attempt, it worked.
i added a no exec to the line aux 0 configuration.
