ACE - Need to permit access to allow remote management to servers
Answered Question
Mar 17th, 2009
I am new to the ACE and having a problem figuring out how to allow the server team to manager their servers sitting behind the ACE modules. Load balancing is working great.
ex...
rserver1 = 172.17.252.10
rserver2 = 172.17.252.11
vip = 172.17.252.15
Currently, the server team is not able to use remote desktop, term services, etc... to manage the real servers...ie .10 and .11. My ACL permits everything and my multi-match policy map only permits access to the vip and applies load-balancing policies.
What do I need to configure to allow the server team to access their rserver IP addresses to manage each box?
Correct Answer by Syed Iftekhar Ahmed about 8 years 4 months ago
If ACLs are in place then you need to make sure that traffic from server team can be routed successfully to/from the real servers.
Upstream routing devices should have routes for your real servers pointing to the ACE.
Syed iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Tue, 03/17/2009 - 10:46
  • Blue, 1500 points or more
Syed iftekhar Ahmed
mcroberts Tue, 03/17/2009 - 11:32
all of the routing is in place and the the real servers gateways are the ACE. I think my issue lies within the policy map permitting traffic in to the real IP addresses, but I cant find a combination that will permit the required traffic to the real servers IP addresses.
access-list IB extended permit ip any any
class-map match-any VIP
match virtual-address 172.17.252.15 tcp eq 80
match virtual-address 172.17.252.15 tcp eq 443
policy-map multi-match client-vip
class VIP
loadbalance vip inservice
loadbalance policy slb
loadbalance vip icmp-reply
interface vlan 252
ip address 172.17.252.4 255.255.255.192
service-policy input client-vip
access-group input IB
Syed Iftekhar Ahmed Tue, 03/17/2009 - 13:05
Policy maps are not needed for "Direct server Access". you just need an ACL and appropriate routes.
Syed
dario.didio Wed, 03/18/2009 - 01:39
  • Silver, 250 points or more
Hi, make sure that you configure the IB ACL on VLAN interface of the serverVLAN too, otherwise your return traffic is blocked.
Kr,
Dario
