Database user/pass
Mar 17th, 2009
In CW2000, we had two different databases (RME, CMF). In LMS 3.x, we now have the following: ipm, dfmInv, ani, dfmFh, dfmEPM, cmf, opsxml, rmeng.
=> Which user name / password do we use to access the new ones? Is there an admin tool that could help us to manage the access priviledges to the DBs?
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 03/17/2009 - 11:27
Direct access to the CiscoWorks databases is not supported. We will be opening up SOME direct access in LMS 3.2, but not before that. If you are concerned about security, you can change the database passwords using the NMSROOT/bin/dbpasswd.pl utility.
