default route and routing protcols
Answered Question
Mar 17th, 2009
  • Bronze, 100 points or more
Hi everybody!
i have few questions:
In the following default route,
ip route 0.0.0.0 0.0.0.0 192.192.192.1
192.192.192.1 is next hop ip address.
Consider the following routing table:
R 199.199.199.0 [120/2] via s0
c 192.192.192.0 is directly connected.
Can i configure a default route as.
Ip route 0.0.0.0 0.0.0.0 199.199.199.2
Here 199.199.199.2 is not the next hop but a an entry from routing table.
I think router will perform recursive look up to send packets using 199.199.199.2
Am i correct?
2) Consider the default route:
ip route 0.0.0.0 0.0.0.0 199.199.199.1
Now in case of rip, rip will automatically advertises the default route .
But in case of eigrp and ospf, we need to redistribute this route using "redistribute static" command. Am i correct?
3) Consider the following routing table
R 199.199.199.0 via s0
C 192.192.192.0 directly connected s0
If i configure default route as:
ip route 0.0.0.0 0.0.0.0 s0
it will appear in the routing table as
C 0.0.0.0 directly connected s1.
Now if we wish to advertise this route using eigrp and ospf, do we need to use the command " redistribute connected" ?
Thanks a lot and have a nice day!
Correct Answer by badalam_nt about 8 years 2 months ago
Hi Sarah,
Additional info after browsing through some other forums:
"In earlier versions of RIP, the default route created using the ip route 0.0.0.0 0.0.0.0 was automatically advertised by RIP routers. In Cisco IOS Software Release 12.0T and later, RIP does not advertise the default route if the route is not learned via RIP."
What IOS do you have on your routers?
Petru
Hi Sarah,
In Routing TCP/IP 2nd edition book it appears the same thing as mentioned by Edison:
RIP will not advertise the default route unless the static route is redistributed into the RIP protocol:
router rip
redistribute static
An alternative method of configuring/advertising the default route is to use the command:
ip default-network
where no matter what you specified (network which must be directly connected to the router, specified by a static route, or discovered by a dynamic routing protocol), RIP will advertise 0.0.0.0 as
the default network, not the network specified .
So instead of
(config)#ip route 0.0.0.0 0.0.0.0
and
(config)#router rip
(config-router)#redistribute static
just use
(config)#ip default-network
In both cases RIP process running on that router will advertise 0.0.0.0 to router's neighbours.
Correct Answer by Edison Ortiz about 8 years 2 months ago
Sarah,
I don't see that happening here and I believe you have something else in the config that is causing this to happen or you have a bug, per the IOS documentation:
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_cfg_info_prot_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Cisco IOS software will source the default network with RIP if one of the following conditions is met:
•The ip default-network command is configured.
•The default-information originate command is configured.
•The default route is learned via another routing protocol or static route and then redistributed into RIP.
Am i correct?
Yes.
You need to redistribute static with RIP.
Still, that's a static route and you must use the redistribute static command.
S* 0.0.0.0/0 is directly connected, FastEthernet0/0
R1#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 1, metric 0 (connected), candidate default path
__
Edison.
Overall Rating: 5 (4 ratings)
Correct Answer
Edison Ortiz Tue, 03/17/2009 - 13:00
  • Hall of Fame,
    Founding Member
Am i correct?
Yes.
__
Edison.
sarahr202 Tue, 03/17/2009 - 14:22
Hi Edison!
"2) Consider the default route:
You need to redistribute static with RIP. "
Edison below is my lab set up;
ra s0---s0 rb s1--------rd
ra s0 194.194.194.1/24
router rip
network 194.194.194.0
rb s0 194.194.194.2/24
s1 192.192.192.1/24
ip route 0.0.0.0 0.0.0.0 192.192.192.2
router rip
network 192.192.192.0
Routing table at rb:
RouterB#show ip route (output omitted)
Gateway of last resort is 192.192.192.2 to network 0.0.0.0
C 192.192.192.0/24 is directly connected, Serial1
C 194.194.194.0/24 is directly connected, Serial0
S* 0.0.0.0/0 [1/0] via 192.192.192.2
routing table at ra:
routerA#show ip route (output omitted)
Gateway of last resort is 194.194.194.2 to network 0.0.0.0
R* 0.0.0.0/0 [120/1] via 194.194.194.2, 00:00:12, Serial0
RouterA#
I find in case of rip, we don't need to redistribute the default route.
Thanks a lot Edison and have a nice day!
sarahr202 Tue, 03/17/2009 - 14:42
Now i removed the " ip route 0.0.0.0 0.0.0.0 192.192.192.2" . I configured ip route 0.0.0.0 0.0.0.0 s1 on rb.
The routing table at ra is:
RouterA#show ip route( output omitted)
R* 0.0.0.0/0 [120/1] via 194.194.194.2, 00:00:11, Serial0
Results:
The rip advertises without " redistribute" command, the default route whether it is configured using ip route 0.0.0.0 0.0.0.0 192.192.192.2 or ip route 0.0.0.0 0.0.0.0 s1
Now i am gonna use eigrp on ra and rb to see if the default route get redistributed automatically.
Rb config:(output omitted)
interface Serial0
ip address 194.194.194.2 255.255.255.0
interface Serial1
ip address 192.192.192.1 255.255.255.0
clockrate 56000
router eigrp 1
no ip classless
ip route 0.0.0.0 0.0.0.0 Serial1
line con 0
line aux 0
line vty 0 4
login
end
Ra config:(output omitted)
interface Serial1
ip address 200.200.200.1 255.255.255.0
clockrate 56000
router eigrp 1
auto-summary
no eigrp log-neighbor-changes
ip classless
routerA#show ip route( output omitted)
Gateway of last resort is not set
RouterA#
The eigrp unlike rip does not advertise the default route without redistribute command. I found the same result for ospf
You guys have a good day!
Correct Answer
Edison Ortiz Tue, 03/17/2009 - 14:43
  • Hall of Fame,
    Founding Member
Sarah,
sarahr202 Tue, 03/17/2009 - 15:26
Thanks Edison!
I truly believe i have bug in my ios after all these are 2500 series routers.
I performed my lab 4 times each time get the same result- rip advertising the default route without" redistribute " command.
Thanks a lot !
P.s yesterday i had interview with cisco gold partner, I took along all my questions that i posted and answers you guys posted.Hiring manager was very much interested in these post( i think he is also net pro member). Let see what happens next .
Correct Answer
badalam_nt Tue, 03/17/2009 - 16:38
Hi Sarah,
router rip
redistribute static
ip default-network
So instead of
and
(config)#router rip
just use
chinkevi_2 Tue, 03/17/2009 - 17:29
i think this is the behavior if you have ip classless. do no ip classless you won't see the default route without redistribution. I don't remember why that is..
Correct Answer
badalam_nt Tue, 03/17/2009 - 17:33
Hi Sarah,
Petru
sarahr202 Tue, 03/17/2009 - 19:55
Hi petru!
IOS (tm) 2500 Software (C2500-I-L), Version 12.1(9), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 13-Jun-01 15:12 by kellythw
Image text-base: 0x03041334, data-base: 0x00001000
thanks a lot!
Edison Ortiz Tue, 03/17/2009 - 17:59
  • Hall of Fame,
    Founding Member
Sarah,
I understand you have limited funds as student but learning IOS for the first time with old software such as the 2500 can be a problem.
If you are inclined and have a powerful computer, I recommend getting GNS3 installed and run recent IOS images virtually.
That's what I do to solve most of the questions here and for my customers without the need of having a physical router.
In your case, you can have the best of both worlds - physical hardware and GNS3 to compare your results.
http://www.gns3.net/
I hate for you to fail your upcoming exam due to false positive from an old 2500 image.
HTH,
__
Edison.
sdoremus33 Tue, 03/17/2009 - 19:31
Edison,
I too am learning and cant afford higher end cisco routers curently have 2600 (*3), and a couple of 2500 series routers
2514
2522, etc.....
So the site you mentioned
can you also emulate Cisco Pix and ASA devices for IPSEC + Can you also simulate DMVPN configurations for studying. hope that makes sense. Thanks I learn alot from your posts in this forum. Take care.
Edison Ortiz Wed, 03/18/2009 - 06:56
  • Hall of Fame,
    Founding Member
Hi Steven,
Yes, you can emulate a Cisco PIX but not an ASA. You can simulate DMVPN by using the IOS routers available (7200, 3700, 3600).
HTH,
__
Edison.
sarahr202 Tue, 03/17/2009 - 19:53
Thanks Edison
But the link says i have to have ios.
So i am back to square one.
sdoremus33 Tue, 03/17/2009 - 20:43
Edison,
What are the requirenments to download the Cisco IOS Images.
I am trying to download Csico Image for say (3600 series router w IPSEC) from cisco site to be used with Dynamips
Edison Ortiz Wed, 03/18/2009 - 06:58
  • Hall of Fame,
    Founding Member
Steven,
You mean requirements as for memory and flash? There isn't as everything is virtual. You set your own limitations in term of memory and flash according to your workstation capabilities.
For instance, you can run more virtual router instances if you download an image that requires only 96MB DRAM vs an image that requires 256MB DRAM.
HTH,
_
Edison.
  • Hall of Fame,
    Founding Member
Sorry Sarah :(
Edison Ortiz Wed, 03/18/2009 - 11:44
  • Hall of Fame,
    Founding Member
Hi Sarah,
I was playing a little more about this subject and found another way to bring a default into RIP.
1) Create an IP route pointing to an interface
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
2) Have network 0.0.0.0 under RIP
R1#sh run | be router rip
router rip
version 2
network 192.168.12.0
network 0.0.0.0
no auto-summary
Here is the remote router's view:
R2#sh ip route 0.0.0.0
Known via "rip", distance 120, metric 1, candidate default path
Redistributing via rip
Last update from 192.168.12.1 on FastEthernet0/0, 00:00:07 ago
Routing Descriptor Blocks:
* 192.168.12.1, from 192.168.12.1, 00:00:07 ago, via FastEthernet0/0
Route metric is 1, traffic share count is 1
And the router generating the default is marking it as a 'candidate default path' so in essence is doing a 'ip default network'.
Advertised by rip
* directly connected, via FastEthernet0/1
Route metric is 0, traffic share count is 1
More information on the ip route command can be found in the 'Usage Guidelines'.
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_ip.html#wp1012824
HTH,
__
Edison.
