Meetme question
Mar 17th, 2009
Hello Folks,
Can you setup a password on the meetme conference?
can you use unity and use some call handlers or something ?
please advice
Jaime Valencia Tue, 03/17/2009 - 15:14
the workarond is to use unity transfer options to reach the meetme and use supervised transfer asking the name and the having unity tell you who is trying to join, then you can accept or deny entrance. but there is really no way to set a pwd. you would need MPE for this feature.
if this helps, please rate
dknov Fri, 05/01/2009 - 14:28
Hi Java,
I was wondering, since initializing meetme conference requires pressing MeetMe softkey button on the phone, how can make it work using Unity?
Jaime Valencia Fri, 05/01/2009 - 15:36
you can join a meeting via unity by just dialing the meet-me DN
but you CANNOT initiate one via unity
dknov Mon, 05/04/2009 - 14:23
oh, do you mean just from the auto-attendant menu?
Jaime Valencia Mon, 05/04/2009 - 14:28
From a call handler if you have configured the meet-me DN as a subscriber or call handler.
If not from a System transfer handler.
Any way you can only join an already started meet-me
