ASA and policy based routing
Mar 17th, 2009
folks
can an asa have two separate external interfaces, each using a different NAT, both connected to the same isp router
i need to route traffic from my internal network through the asa and filter it based on destination address - all for http traffic
sounds a bit like policy based routing where i could use a route map and acls to match the destination
i'd appreciate any advice
thanks
seibertmedia Fri, 03/27/2009 - 10:40
you can use policy based nat to set the outgoing IP based on destination ip....
