LMS 3.1 Installation on Solaris
Answered Question
Mar 17th, 2009
I finished installing LMS 3.1 on a Solaris box. Installation went smooth. I cannot access the web interface of LMS 3.1 using the 1741(http) or 443 (https) ports. Following is the end message:
===================- Possible Warnings/Errors Encountered -===================
WARNING: Ensure that you have installed the recommended Solaris 10 cluster patch es released
WARNING: on Apr/17/07, in this server.
WARNING: If these cluster patches are not installed, please download and install them
WARNING: from http://www.sun.com/.
WARNING: Otherwise, some features of the CiscoWorks applications will not functi on properly.
WARNING: Exiting installation beyond this point might result in system instabili ty.
WARNING: '/etc/inetd.conf' already contains an entry for tftp server.
WARNING: To ensure that you retain the latest device support,
WARNING: please install the latest Device Packages from Cisco.com @
WARNING: http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme
WARNING: Please refer to the Installation and Setup Guide for details.
WARNING: To ensure that you retain the latest device support and bug fixes, plea se install
WARNING: the latest Service Pack (SP) for Campus Manager 5.1
WARNING: You can download the latest SP from Cisco.com, at http://www.cisco.com/ cgi-bin/tablebuild.pl/cw2000-campus.
WARNING: User Tracking Utility 1.0 is not compatible with Campus Manager 5.1
WARNING: User Tracking Utility 1.1.1 is available for Campus Manager 5.1
WARNING: You can download the latest UTU from Cisco.com, at http://www.cisco.com /cgi-bin/tablebuild.pl/cw2000-campus-crypto.
WARNING: Neither HP-OpenView or NetView is installed.
WARNING: To ensure that you have up-to-date device support,
WARNING: install the latest Service Pack (SP) from Cisco.com, at
WARNING: http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-dfm.
WARNING: For installation details, refer to the DFM Installation and Setup Guide
How can I verify installation after LMS 3.1 finishes installing on Solaris? and How can I start stop services after I am not able to get to the web interface of LMS 3.1 after installation?
Follwing is my server specs:
Solaris 10 10/08 s10s_u6wos_07b SPARC
Patch cluster as of 2009-03-09 has been
Memory size: 16256 Megabytes
CPU - SUNW,UltraSPARC-T2
Correct Answer by Joe Clarke about 8 years 2 months ago
Yes, you must install as root. But regardless, you need to make sure the permissions of the underlying NMSROOT file system mount point are 0755. If this is not the case, LMS will fail to run.
Overall Rating: 5 (2 ratings)
Joe Clarke Tue, 03/17/2009 - 15:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to reboot before using LMS as /etc/system gets changed.
When the server reboots, /etc/rc3.d/S10dmgtd should be executed automatically (yeah, we're not using svcadm yet). That should start Apache and Tomcat. After about 30 minutes, everything within LMS should be reachable.
If not, post the output of /opt/CSCOpx/bin/pdshow.
Joe Clarke Thu, 03/19/2009 - 11:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the daemons.log.
Joe Clarke Thu, 03/19/2009 - 14:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is a clear permissions problem here. And I think I know where. Unmount the file system which holds /opt/CSCOpx (or where ever the actual NMSROOT is). Make sure the permissions on the mount point are 0755.
For example, if /opt/CSCOpx is mounted on /opt (i.e. /opt is a file system), unmount /opt:
umount /opt
And look at the permissions on /opt:
ls -ld /opt
They need to be:
drwxr-xr-x root other ...
abalasan08 Fri, 03/20/2009 - 07:20
I am thinking of rebuilding the server and reinstalling LMS 3.1. When I install LMS 3.1, should I install it as Root?
Correct Answer
Joe Clarke Fri, 03/20/2009 - 12:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
