Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928830members
1242671discussions
Community Activity
Resolved! Dual ISP connection gi0/2 not able to connect to internet
Hello,I need your help - currently we have a  2921 Cisco router connected to dual ISPs using "gi0/0 & gi0/1" and we are able to connect to either ISP successfully.  Once we connect gi0/2 to any device the connected switch is not able to access the in...
dgrant524 by Level 1
  • 74 Views
  • 8 replies
WLC 5508 licenses
I have a WLC with 11 registered access points I tried to integrate a new equipment, but I see that I already have my 37 licenses in use. Can you guide me and let me know what this is due to?there is a way to release licenses from the WEB portal or...
angelalmaras_0-1713897847230.png angelalmaras_1-1713898066080.png angelalmaras_2-1713898103303.png
Client Failed to associate
Hello Team, I get some clients on Guest failing to associate. And this is what I find in Prime events about one of the clients.Can someone help with the explanation for this event and the fix.Also client is supposed to get the EUP page and accept it....
collrbbrt by Level 1
  • 115 Views
  • 6 replies
Resolved! Stop in progress template provisioning
Hello everyone.  I'm very new to DNAC or Catalyst Center.  I've setup a project with a template to add a simple configuration to switches.  It currently has been in progress for 10 days and hasn't made a change to a switch yet.  I'd like to cancel th...
Gricel by Level 1
  • 36 Views
  • 2 replies
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
unknown IPs in FTD outbound logs
I am managing FTD-1120s with FMCv both running v7.2.1 software.  In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots".   When I search for events that match this rule, most of the traffic is from inte...
tato386 by Level 6
  • 166 Views
  • 6 replies
  • 1 Helpful votes
IP routing using domain
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 296 Views
  • 12 replies
Extremely slow and poor overall WiFi quality with C9130AXI
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
NexCyb by Level 1
  • 23 Views
  • 0 replies
Cisco Secure Client CVE-2024-20337
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 223 Views
  • 6 replies
