2621XM router not retaining configuration
Mar 17th, 2009
I have recently purchased a used 2621XM router and have found that when I turn off or discconnect the power, the config is not retained.
... and before you ask, yes, I have saved the config from running to startup.
The only change that I have done after getting the router was to upgrade the IOS from c2600-is-mz.123-10 to c2600-adventerprisek9-mz.124-23.
Does anyone know how or why this would occur and does anyone know if this has happened before?
Yudong Wu Tue, 03/17/2009 - 20:55
1. check if config register number is set correctly. Does "show start" have right config?
2. might be a bad NVRAM or battery for NVRAM is bad.
darrenoleary Wed, 03/18/2009 - 03:39
Issue resolved. Thanks.
It was the config register that was the issue.
Thanks again.
