CME 4.0 Unable to make out going calls neither i can receive in coming call
Mar 17th, 2009
Hi Guys
I have configred 2811 router with CME 4.0, the ip phones are configured properly but the problem is with incoming and outgoing calls, when ever i try to make a call, after dialing the complete number i get an engage tone, same thing is happening with the incoming, the incoming call is not landing on the configured ip phone below are the voice ports and dial peer configuration
voice-port 0/1/0
trunk-group FXOPORTS
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-SIEMENS
supervisory dualtone-detect-params 1
timeouts call-disconnect 5
connection plar opx 418
caller-id enable
--More-- !
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
--More-- supervisory dualtone-detect-params 1
caller-id enable
dial-peer voice 203 pots
trunkgroup FXOPORTS
description *** Mobile Dial-Peer ***
destination-pattern 905[056].......$
prefix 05
dial-peer voice 215 pots
trunkgroup FXOPORTS
description *** TollFree Dial-Peer ***
destination-pattern 9800T
prefix 800
--More-- !
dial-peer voice 206 pots
trunkgroup FXOPORTS
description *** National Dial-Peer ***
destination-pattern 90[1-4,6-9].......$
prefix 0
dial-peer voice 204 pots
trunkgroup FXOPORTS
description *** Landline Dial-Peer ***
destination-pattern 9[2345789]......$
dial-peer voice 202 pots
trunkgroup FXOPORTS
description *** Emergency Dial-Peer ***
preference 7
destination-pattern 9[19]..$
prefix 6
A quick reply will be highly appreciated.
Cheers
Aamir
aamirdhedhi Wed, 03/18/2009 - 23:13
yes the lines have been tested on the regular telephone, there is one thing that i have noticed below is the description when i use the command
(show dial-peer voice)
(Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 16, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "22 ",
Last Disconnect Text is "no circuit (34)",
Last Setup Time = 16014477.)
I already have a running setup with the same hardware and configuration in our other location which is working stable, the out put of the (Show dial-peer voice) is as follows
Connect Time = 1170159, Charged Units = 0,
Successful Calls = 128, Failed Calls = 0, Incomplete Calls = 0
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 82279145.
Last Disconnect Time = 82294945.)
The difference is the last disconnect cause and the last disconnect text.
Please reply thanks for your support
Cheers
Aamir
Paolo Bevilacqua Wed, 03/18/2009 - 23:15
Need to see the debug vpm output. Might be a battery denial issue requiring some configuration under voice-port.
Paolo Bevilacqua Thu, 03/19/2009 - 09:16
Hi, have the lines checked again, router detects power denial, might be a low line voltage, etc. Sometime, swapping tip and ring wires helps.
