Replacing two SUP720-BASE with two SUP720-3B in CAT 6500 chassis
Mar 17th, 2009
I have never done this before, but will this work.
Will the switch tolerate a SUP720-BASE and a SUP720-3B to be in the same switch for a short period of time.
Customer wishes to replace two SUP720-BASE with two SUP720-3B without any downtime or maintenance window.
Ofcourse IOS will be same.
Procedure we plan to follow:
1. Remove standby SUP 720-BASE (Slot 8)
2. replace with SUP-720-3B ( Slot 8 )
3. wait for sync and status to return as good HA state
4. perform a soft sup switch command
5. Remove 720-Base ( Slot 7)
6. replace sup with 720 3B ( Slot 7)
7 wait for ok status
8 Perform soft sup switch to return to normal
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Wed, 03/18/2009 - 01:16
  • Hall of Fame,
    Founding Member
Hello Alphonse,
SSO requires the two supervisors to be of the same model.
RPR guidelines say that if the two supervisors are not identical one of the two will be kept in reset state
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/redund.html#wp1095529
actually the same is written in HW restrictions of SSO
I would negotiate a maintanance window
point 3 should not happen.
And then if you remove the active sup while the new inserted one is in reset state you have out of service for sure.
I would:
remove one Sup 720
some hours later during maintanance I will insert sup 720 3b
remove sup 720
insert second 720 3B
hope to help
Giuseppe
Leo Laohoo Wed, 03/18/2009 - 15:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Is your new Sup blade have the same IOS as the master?
What is your Test Verification Plan?
What is your Backout Procedure?
What is your Window?
