Restoration of crashed node from Backup(IPIVR/IPCCX HA)
Mar 18th, 2009
What are steps for the restoration of crashed node?
e.g. If node 2(non-publisher) crashes, then I install OS,CRS software.Further how to restore the config & DB for node2.
Will the restoration be from node 1(assuming node1 is configured to take backups) ?
irisrios Tue, 03/24/2009 - 16:05
Do the following:
- Switch the DB publisher from the crashed node to the working node.
- Remove the crashed node from the cluster by executing the Remove option in Control Center Server Configuration page in the CRS Application Administration web interface on the non-crashed node.
- Re-image the crashed node.
- Re-install CRS on the crashed node, and execute the Add To Cluster selection as part of the CRS Administration configuration.
One node on a CRS 5.0 two-node cluster crashes beyond repair (Page 66):
