ping from PC1 can not reach R1 and PC2.
Mar 18th, 2009
I don't know why. I'm testing Vlan
principle. Can anyone help me?
R1 : E0 10.43.6.1, E1 10.43.4.1
SW1 : 10.43.6.2 SW2 : 10.43.4.2
PC1 : 10.43.6.5 PC2 : 10.43.4.5
E0 from R1 connects Port1 from SW1
Port2 from SW1 connects PC1
E1 from R1 connects Port1 from SW2
Port2 from SW2 connects PC2
and here is configuration for SW1
SW1#vlan database
SW1#vlan 20 name test
SW1#conf t
SW1#int FE0/1
SW1#switchport access vlan 20
SW1#int FE0/2
SW2#vlan database
SW2#vlan 20 name test
SW2#conf t
SW2#int FE0/1
SW2#switchport access vlan 20
SW2#int FE0/2
Giuseppe Larosa Wed, 03/18/2009 - 01:06
  • Hall of Fame,
    Founding Member
Hello Sangbong,
you have only one router connected to the two switches
verify on PC1 that you have provided the right default gateway
use ipconfig /all it has to be 10.43.6.1
you can check the ARP table with arp -g on the PC
on the router verify that ip routing is enabled
conf t
ip routing
PC2 has to use as DEf GW 10.43.4.1
Hope to help
Giuseppe
