VIC2-2FXS problems
Mar 18th, 2009
we have ISR 2801 router with 2xVIC2-2BRI-NT/TE, 1xVIC2-2FXS and PVDM2-8, IOS ver.c2801-spservicesk9-mz.124-9.T7.bin. We can see ISDN BRI ports but cannot see FXS ports.
Any help?
here some outputs from router:
sh ver.
Cisco 2801 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FCZ121412Q8
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
2 Voice FXS interfaces
1 DSP, 4 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
126976K bytes of ATA CompactFlash (Read/Write)
sh invent
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801 , VID: V04 , SN: FCZ121412Q8
NAME: "VIC 0", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE , VID: V02 , SN: FOC12093QZW
NAME: "WIC/VIC/HWIC 1", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE , VID: V02 , SN: FOC12093QL0
NAME: "WIC/VIC 2", DESCR: "2nd generation two port FXS voice interface daughtercard"
PID: VIC2-2FXS , VID: V01 , SN: FOC12121ZWM
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8 , VID: V01 , SN: FOC12085ZJS
sh voice port summ
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 1 bri-voice up dorm none none y
0/0/0 2 bri-voice up dorm none none y
0/0/1 1 bri-voice up dorm none none y
0/0/1 2 bri-voice up dorm none none y
0/1/0 1 bri-voice up dorm none none y
0/1/0 2 bri-voice up dorm none none y
0/1/1 1 bri-voice up dorm none none y
0/1/1 2 bri-voice up dorm none none y
mljevakovic Wed, 03/18/2009 - 03:49
I found out a solution. The problem is generated by insufficient DSP resources (PVDM2-8, I need more...).I had rearranged the position of the card and of course I've lost one ISDN BRI port. The result is as follow:
sh voice port summ
IN OUT
0/1/0 -- fxs-ls up dorm on-hook idle y
0/1/1 -- fxs-ls up dorm on-hook idle y
0/2/0 1 bri-voice up dorm none none y
0/2/0 2 bri-voice up dorm none none y
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
I hope that this will help anyone with this situation.
