03-18-2009 02:24 AM - last edited on 03-15-2019 04:55 PM by NikolaIvanov
I have a CME router connecting to the gatekeeper and i have made a trunk from CCM to gatekeeper
Config :-
CME
dial-peer voice 1 voip
destination-pattern [1-2]...$
voice-class codec 1
session target ras
tech-prefix 1
gatekeeper
show gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
10.1.202.1 1720 10.1.202.1 52683 cme VOIP-GW
H323-ID: CME-HKG
Voice Capacity Max.= Avail.= Current.= 0
10.1.200.20 56014 10.1.200.20 51209 ccievoice3 VOIP-GW
H323-ID: HQ_Trunk_2
10.1.200.21 52699 10.1.200.21 51483 ccievoice3 VOIP-GW
H323-ID: HQ_Trunk_1
Total number of active registrations = 3
in CCM
I have made a inbound translation pattern.
My translation pattern/ is ok my css is ok but still call are not rounting to the ip phone.
Also when i am doing outbound i am not be able to call to cme
The error message is
*Mar 18 10:02:22.582: rassrv_get_addrinfo: (11005) Matched tech-prefix 1
*Mar 18 10:02:22.582: rassrv_get_addrinfo: (11005) unresolved zone prefix, using
source zone cme
*Mar 18 10:02:22.582: rassrv_arq_select_viazone: about to check the source side,
src_zonep=0x46B29DBC
*Mar 18 10:02:22.582: rassrv_arq_select_viazone: matched zone is cme, and z_invi
anamelen=0
*Mar 18 10:02:22.582: rassrv_arq_select_viazone: about to check the destination
side, dst_zonep=0x46B29DBC
--More--
*Mar 18 10:02:22.582: rassrv_arq_select_viazone: matched zone is cme, and z_outv
ianamelen=0
*Mar 18 10:02:22.582: rassrv_get_addrinfo: (11005) tech-prefix gateway selection
failed.
I wanted to want is tech-prefix gateway selection failed.
As i dont want to use zone prefix or default prefix in gatekeeper
I know its archievable my still its not working.
Can anyone please help me fast.
03-24-2009 07:06 AM
Tech prefix will not work when the E164 registration is enabled and the gateway has E164-ids available. You can use either "e164 register" or "tech prefixâ but not both.
Make sure you have only one local zone if there is only ONE gatekeeper.
Make sure your CallManager has been properly configure under the Device>Gatekeeper Option
04-10-2009 08:11 PM
Are you still having issues here? Send me an email to jdelgado@redesfusionet.com I will give you a hand
