Cannot connect via VPN.
Mar 18th, 2009
Hi guys,
I apologise for posting this thread in this forum, it is because it is pretty urgent and I always get a faster response here.
Can someone please help with this, there is a vpn set up between two of our remote sites, I'll call them site A and B. Site A has a site-to-site VPN set up to Site B and Site B has a leased line connection to the head office.
I now want site A to be able to connect via its VPN connection in Site B through to a server in the head office to pick up files etc.
Please direct me as to how I can achieve this.
A 3rd party company manage the VPN between site A and B and they have assured me that all IP is allowed through.
There are Cisco routers as endpoints at both sites A and B and a Pix at the Head office.
The site A and B network have been defined on the Head office Pix and the access rule has been created allowing http/https access which is all that is required.
When they try to browse to the server from site A, I am not even seeing anything in my logs.
Thanks for your time.
Martha
mvsheik123 Wed, 03/18/2009 - 07:14
  • Gold, 750 points or more
My understanding is...
Site A<--L2Lvpn-->SiteB <--Leased line-->Head office
Site A Need to be able to get to a server ex: 192.168.100.100 at Head office.
Try the below:
Site A:
1. L3 device has static route point to site B to reach server
2. Access-list statements on VPN device so that The traffic to Server from Site A goes unencrypted/via tunnel (same tunnel to Site B)
Site B:
As Site B aready aware of Site A and Head office- routing part is completed.
1. Access-list statements on VPN device so that The traffic FROM Server TO Site A goes unencrypted/via tunnel (same tunnel to Site A)
Head Office:
1.L3 device has static route point to site B to Site A.
Hth
MS
mfawehin Wed, 03/18/2009 - 07:21
Hi MS,
Thanks so much for your response. I will liaise with the 3rd party support partner and confirm that the site A device is configured accordingly and I will check the site B device as well.
I just want to make sure I understand your instructions regarding the Head office though, do you mean a static route to site A with the site B device as next hop?
I will let you know how I get on.
Martha.
mvsheik123 Wed, 03/18/2009 - 07:33
"do you mean a static route to site A with the site B device as next hop?"
That is correct.
hth
MS
