Can i configure site to site & remote access vpn on single ASA 5520
Mar 18th, 2009
I have configured remote access vpn for mobile users. VPN tunnel for remote access users is terminated on outside interface of ASA. Outside interface of ASA is configured with public ip and inside interface of ASA is configured with private ip. Remote access VPN is working fine.
Now i want to configure site to site vpn also on the same ASA box. Is it possible and if yes then can i use same global ip which i have configured on outside of ASA to terminate VPN tunnel for both remote access and site to site vpn.
Need help on this.
Nishith
mfreijser Wed, 03/18/2009 - 05:22
  • Bronze, 100 points or more
Hello Nishith,
Lucky for you you can use only one IP address on an interface for configuring any kind of VPN tunnels.
This means you _have_ to use the same global ip for all your VPN tunnels, regardless of what type they are :)
Michaël
