Access Point 1310 not Pinging
Mar 18th, 2009
We are trying to connect two Access points 1310 (AIR-Br-1310G-A-K9-R)with each other but they are not pinging, pls suggest what could be reason.
Thanks & Regards
jeff.kish Thu, 03/19/2009 - 06:56
  • Silver, 250 points or more
These bridges require external antennas. What kind of antennas are you using, and how far away from each other are they?
If you can, please post the configs for the bridges so we can see if there's a configuration error.
Jeff
csco10904480 Sun, 03/22/2009 - 23:15
hi,
will Access points 1310 (AIR-BR-1310G-A-K9-R) ping if we keep both acess points side by side without antenna.
Shortly i will send you config. details.
Thanks & Regards
Leo Laohoo Mon, 03/23/2009 - 15:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Deo,
Sure if the IP Addresses are configured correctly.
I hope you are leaving these AP's without any antennaes for long. There have been several cases of the radios failing because of the absence of antennaes.
