Problem with re-imaging local controller 210
pawel.swiecki
I was downloading DVD image vers. 6.0.2. After installation process system not started. On the console i see "LI" communicate. Maybe the image is bad???
What is the solution?
Regards, Pawel
Farrukh Haroon
Compare the MD5 checksum of the image with the one mentioned on the site. If it does not match, re-download the image :).
Farrukh
The md5 checksum is correct. During the installation process appears communicates for example:" /cdrom/bin/tar: lib/modules.pcimap: Could not create file: No such file or directory". There are a few similar communicates. After finishing installation process and reboot device I see communicate: "Li".
Maybe the disk storage with RAID is bad?, but under the diagnostic program I can't see problem.
I tried with many versions of software: from 5.3.5 to 6.0.2 - there are similar problems.
Pawel
I would open a TAC Case at this point, if that is possible.
Farrukh
