IPSec on 2811
Answered Question
Mar 18th, 2009
I have looked through the NetPro forums for a couple of days now and have not found my answer.
My question is, how do I setup an IOS based IPSec VPN tunnel using a 2811 with IOS os SP Services 12.4(13)?
Let me know if you need any more information.
Thank you,
Richard
Correct Answer by Mark Yeates about 8 years 2 months ago
Richard,
I was just looking at the feature navigator and it appears that the SP services IOS does not support Easy VPN. I would recommend using one of these feature sets:
Advanced Security
Advanced IP Services
Advanced Enterprise Services
You can order this feature set upgrade through your Cisco partner.
HTH,
Mark
Overall Rating: 5 (1 ratings)
Mark Yeates Wed, 03/18/2009 - 11:16
  • Gold, 750 points or more
Richard,
Are you planning to connect two of these routers for your VPN tunnel? Attached is a template I created a while back and may be useful for you. Also you can use the SDM GUI to create the tunnels. If you don't have the SDM files they can be downloaded here.
http://www.cisco.com/cgi-bin/tablebuild.pl/sdm
HTH,
Mark
rsvensson Wed, 03/18/2009 - 12:28
Mark,
I am unable to input the command crypto isakmp...the only options under crypto are:
ca
engine
key
pki
provisioning
wui
What do I need to have in order to use VPN on this device?
I have attached a show version incase it may help.
Richard
Correct Answer
Mark Yeates Wed, 03/18/2009 - 12:55
Richard,
Advanced Security
HTH,
Mark
Mark Yeates Thu, 03/19/2009 - 11:18
You are most welcome! Glad I was able to help, and hope that template will be of use for you when you get the correct IOS loaded.
Best of luck!
Mark
