Adminstrative distance for route
Answered Question
Mar 18th, 2009
  • Bronze, 100 points or more
Hi every body!
i have few questions;
ip route 10.0.0.0 255.0.0.0 202.202.202.1
where 202.202.202.1 is next hop ip address.
ip route 10.0.0.0 255.0.0.0 s0
Now i configured both these routes on a router then the Ip route 10.0.0.0 255.0.0.0 s0 will be picked and installed in the routing table with" s" symbol indicating it is static route.
That means both routes have Ad=1 but ip route 10.0.0.0 255.0.0.0 s0 is chosen because the metric value for directly connected route is zero. am i correct?
thanks a lot and have a nice day!
Correct Answer by Edison Ortiz about 8 years 1 month ago
A directly connected route has an AD of 0. A static route has an AD of 1.
That's not correct
http://cciepursuit.wordpress.com/2007/07/09/the-administrative-distance-of-a-static-route-pointed-to-an-interface-is-not-zero/
HTH,
__
Edison.
How come i only find one route in routing table ?
Another bug in your IOS? :)
I don't know.
As another poster indicated, it recursives within CEF.
R1#sh ip cef 1.1.1.1
1.1.1.1/32
attached to FastEthernet0/0
nexthop 192.168.12.2 FastEthernet0/0
BTW, do you have cef enabled?
__
Edison.
No, they will be load-balanced.
Rack1R1#sh run | i ip route
ip route 1.1.1.1 255.255.255.255 FastEthernet0/0
ip route 1.1.1.1 255.255.255.255 155.1.146.4
Rack1R1#sh ip route 1.1.1.1
Routing entry for 1.1.1.1/32
Known via "static", distance 1, metric 0 (connected)
Routing Descriptor Blocks:
155.1.146.4
Route metric is 0, traffic share count is 1
* directly connected, via FastEthernet0/0
HTH,
__
Edison.
Overall Rating: 5 (3 ratings)
lamav Wed, 03/18/2009 - 09:27
  • Blue, 1500 points or more
"the metric value for directly connected route is zero. am i correct?"
Correct.
Jon Marshall Wed, 03/18/2009 - 09:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
In addition to previous posts.
If the next hop is the interface then the router will have to arp for all destinations.
If the next hop is an IP address then the router only needs the mac-address for that IP address.
Jon
lamav Wed, 03/18/2009 - 09:40
And just to add to what Jon said, that scenario can really suck if the next hop is the Internet and your router is going to send out an ARP request everytime someone goes to a new website.
Correct Answer
Edison Ortiz Wed, 03/18/2009 - 09:40
  • Hall of Fame,
    Founding Member
155.1.146.4
HTH,
__
Edison.
lamav Wed, 03/18/2009 - 09:51
Wow, that's interesting. I never tested it in a lab, like you just did, but it seems to go against everything we have ever read about static routes and directly connected interfaces.
sarahr202 Wed, 03/18/2009 - 10:04
Thanks Edison!
I configured :
Show ip route;
routerB#show ip route
(output omitted)
S 10.0.0.0/8 is directly connected
is directly connected, Serial0
C 201.201.201.0/24 is directly connected, Serial1
C 202.202.202.0/24 is directly connected, S0
In my set up only one route is installed whose metric =0
But in your example, i see
155.1.146.4
metric=0 in both cases, my question if traffic is load balancing , these two routes must be present. In your case both routes are in routing table.
thanks a lot!
lamav Wed, 03/18/2009 - 10:08
Sarah, whats the IP address of s0 on your router?
Edison, whats the IP address of f0/0 on your router?
Edison Ortiz Wed, 03/18/2009 - 10:22
  • Hall of Fame,
    Founding Member
155.1.146.1
Not sure what's the point.
Correct Answer
Edison Ortiz Wed, 03/18/2009 - 10:11
  • Hall of Fame,
    Founding Member
I don't know.
1.1.1.1/32
__
Edison.
izackvail Wed, 03/18/2009 - 09:54
It will actually install both routes. It will install the "ip route 10.0.0.0 255.0.0.0 202.202.202.1" as a recursive route. It will install "ip route 10.0.0.0 255.0.0.0 s0" as a directly connected route. When it goes to send traffic it will attempt to recurse to the next hop route. If the router has another route (via a dynamic routing protocol) it will use that for recursion. If not it will use the static directly connected route and attempt to send the traffic out that interface. If that is a multipoint interface it will have to do layer 3 to layer 2 resolution via arp or some other means depending on the encapsulation on the interface.
lamav Wed, 03/18/2009 - 09:59
"It will install the "ip route 10.0.0.0 255.0.0.0 202.202.202.1" as a recursive route. It will install "ip route 10.0.0.0 255.0.0.0 s0" as a directly connected route."
A directly connected route has an AD of 0. A static route has an AD of 1. So why would it place both routes in the routing table when one has a better AD?
lamav Wed, 03/18/2009 - 10:39
Oh, my God!
I'm a victim of an urban legend! Damn, I feel so deceived, so humiliated, so disillusioned. What's the world coming to when you can't trust what Cisco says about its own equipment?!?!
Alas, were it not for my cyber hero, Edison, I would have continued being a victim of false propaganda. Thanks, papi.
Sarah, you may be running an old version of code. According to that link Edison sent me, the AD of a static route pointing to an interface USED to be zero, not after 12.2. though....
Edison Ortiz Wed, 03/18/2009 - 10:42
  • Hall of Fame,
    Founding Member
She is and that's the reason she posts for extra confirmation.
She is a student with limited funds :(
Giuseppe Larosa Wed, 03/18/2009 - 11:17
  • Hall of Fame,
    Founding Member
Hello Victor,
you are not alone on this ...
Best Regards
Giuseppe
lamav Wed, 03/18/2009 - 11:45
Giuseppe:
If you were thinking the way I was, then I can say Im flattered. :-)
