Upgrading CCME
Afragoso2009
HI team
I have a CCEM 4.0 and I need to upgrad to 4.2
How Can I do it keepinh the actually configuration
I had the “cme-124-20T1.zip” .This is the corecty file ?
Brgds
david-lima
Level 4
Level 4
Hi friend, check this CME and Cisco IOS Software Version Compatibility Matrix link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Make a backup of your configuration, after you install your CME file in your flash, you need to upgrade the firmware versions on a Cisco Unified IP phone running SCCP,
enable
configure terminal
tftp-server device:firmware-file
telephony-service
load phone-type firmware-file
create cnf-files
end
You will need to reload your router if there is a new IOS and your atual configuracion will be loaded.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1071374
Best regards
David
Hi David
My IOS is 12.4(13r)T
I will need to uprad the IOS
