SQL data types
Mar 18th, 2009
I have an sql table I am using with ipcc express. one of the fields in the sql table is datatype = Timestamp
when I use the DB read step in script editor ipcc can see the fied in the database and reads it as java.sql.Timestamp
but there is not variable in IPCC that will match this, does any one know what variable type in IPCC can be used with data type = time or timestamp or datetime in sql?
thanks
