Cisco Unity Ports issue
Mar 18th, 2009
Recently I added additional ports in the unity telephony integration manager for the integration with CCM. The ports are registered with CCM and everything works great. The issue is that, i am not able to see the DNs of new the ports added in UTIM where as the old ones are listed correctly. Am I missing anything here?
kraghavansag Wed, 03/18/2009 - 12:00
Yes. I would not able to add new ports if there are no additional licenses.
Jaime Valencia Wed, 03/18/2009 - 13:56
  • Cisco Employee,
  • Hall of Fame,
    2011
did you restarted unity after modifying the integration in UTIM??
java
if this helps, please rate
kraghavansag Wed, 03/18/2009 - 14:36
Yes. I did multiple times. It looks like I may have to re-add the ports again in Unity. A TAC engineer suggested that.
