Netflow on c4948
Mar 18th, 2009
Hello All,
I'm trying to enable Netflow on a c494 but no luck so far.
ip cef is not globally enabled but is active as is shows entries when issuing "show ip cef".
At this stage none of the netflow configurations commands are available through the cli.
Do I have to enable cef globally in order to configured netflow on the switch?
Thibault.
Collin Clark Wed, 03/18/2009 - 13:49
  • Purple, 4500 points or more
Netflow is not currently supported on the 4900 series switches.
Hope that helps.
