Ciscoworks 3.1 upgrade or fresh
Answered Question
Mar 18th, 2009
my customer has purchased: CWLMS-3.1-5KUPK9. Am I able to do a fresh install of 3.1 or must 2.6 be installed first?
thanks in advance
Correct Answer by Martin Ermel about 8 years 3 months ago
Yes you can do a fresh install and if somehow possible this should be the preferred method (in my opinion);
if it is on Windows make sure you do the installation as the local admin and that the TEMP and TMP variables are set to something short (like C:\Windows\Temp) for both the system and the administrator (as whom you are doing the installation);
also disable any antivirus sw during installation.
Overall Rating: 5 (1 ratings)
Correct Answer
Martin Ermel Wed, 03/18/2009 - 12:39
  • Blue, 1500 points or more
