waas optimization problem
Mar 18th, 2009
Hi all,
I'm having a setup in which I have a branch router on which there is a NME-WAE 502 running version 12.4.15T1-advipservices
and HO 612 WAE. WCCP is being used for interception. the router at the HO performing redirection is a 1841 running 12.4.21a-advipservices. The problem is that I'm seing traffic on both WAEs as being optimized but in fact it is not happening all files are taking the same time. I reviewed the config hundreds of time and I'm positive that it should work
Overall Rating: 1 (1 ratings)
k.abillama Fri, 03/20/2009 - 08:50
Mine is 12.4.15(T1) in the branch and is working.
Anyways I solved the problem it was a loop on one of the switches.
Thanks anyways
