Exporting BAT Data from 3.3 to import into 7.0
Mar 18th, 2009
I am upgrading a system, but NOT migrating with DMA, question is when exporting data with BAT from 3.3 I cannot import into 7.0 with bulk admin as the fields for all details do not match. If I were to uprade the publisher to 4.1(3) since that is migratable to 7.0, then would a BAT export indeed match ?? I would like to do a phone export, all details, then on the new system do an all detail import. I know what you are thinking and asking, just want to know if 4.1.3 will match or not, I'm not worried about licensing, very small system
Jaime Valencia Wed, 03/18/2009 - 13:53
  • Cisco Employee,
  • Hall of Fame,
    2011
no, they won't match. either case needs you to do some manual work on the file to match the fields for 7.x
java
if this helps, please rate
