03-18-2009 01:45 PM - edited 03-06-2019 04:41 AM
I am upgrading my 6509 chassis that currently run SupII with 1300W a/c power supplies with Sup720 and 2500W a/c power supplies. I did not notice the power plug for the 2500W supply required a 220v connection. Can I run these on 110V cords?
Solved! Go to Solution.
03-18-2009 02:29 PM
Mike,
Are you using 2500W or 3000W power supplies? Either way you should be fine.
Note: If you are going to use 110V to the power remember that they are running in combined mode. If one of the two power supplies fail or gets unplugged it will not be able to fully support the chassis and shut down some line cards.
Mark
03-18-2009 01:53 PM
Check this link-
Hope that helps.
03-18-2009 01:53 PM
Yes, you can run 110V to the power supplies. Problem is that since you are cutting the input in half, so will the output on the power supplies. In order for your SUP720's to work you may have to run the power supplies in combined mode. There may not be any redundancy with the power supplies.
HTH,
Mark
03-18-2009 02:14 PM
I used Cisco's power calculator and looks like I would be fine.
The chassis would have:
2 - Sup720-3b
2 - WS-X6148A-RJ-45 line cards
2 - 300W P/S
Total Draw Combined WS-CAC-3000W 54%
03-18-2009 02:19 PM
I replied with the wrong amount of line cards this is what is installed
2 - Sup720-3b
5 - WS-X6148A-RJ-45 line cards
2 - 3000W P/S
03-18-2009 02:29 PM
Mike,
Mark
03-18-2009 02:48 PM
I am using the 3000W P/S.
03-18-2009 02:32 PM
Mark's post is valid, you will not have power supply redundancy with a combined power utilization of 54%. If you want redundancy, drop that number below 50% and create room for any extra cards you may put in.
