Extention Mobility Large Scale
Mar 18th, 2009
Over a large deployment of multiple sites (with SRST gateways) and possible of 2 call manager clusters is extension mobility a good deployment strategy? What are the possible issues that could arise with this type of deployment if any?
Jaime Valencia Wed, 03/18/2009 - 14:31
  • Cisco Employee,
  • Hall of Fame,
    2011
EM does not work intercluster, you would need to create a profile for same user on each cluster if he will move between offices, consider that
java
if this helps, please rate
lyle.stevens Wed, 03/18/2009 - 14:38
That's great to know but what about a single cluster? Will having all users as extension mobility cause any issues? What about in SRST mode?
Jaime Valencia Wed, 03/18/2009 - 14:58
  • Cisco Employee,
  • Hall of Fame,
    2011
in a single cluster you only need 1 profile
Q. Does Cisco Unified SRST support Extension Mobility?
A. Cisco Unified SRST routers do not support Extension Mobility. IP phones rely on the support from Cisco Unified Communications Manager for Extension Mobility support. When in SRST mode, IP phones fall back to the SRST router with whatever profile it contains (extension#, .., etc.).
java
