Trying to remove crypo entry from the ASA
Mar 18th, 2009
I am trying to remove the following entry but it does not seems to delete on the asa.
crypto map vpn xx set security-association lifetime seconds 3600
crypto map vpn xx set security-ssociation lifetime kilobytes 4608000
These are the only lines in crypto entry and I am trying to cleanup. No luck. Does anyone know why or how I can remove them.
DialerString_2 Fri, 03/20/2009 - 07:12
  • Bronze, 100 points or more
I ran into the same problem yesterday. I had to remove the lines from the ASDM.
dradhika Fri, 03/20/2009 - 10:59
  • Cisco Employee,
Try giving "clear configure crypto" in config mode.
HTH,
Radhika
