03-18-2009 03:50 PM - edited 07-03-2021 05:20 PM
I have a WRT64G2 4-port wireless hub and only use it with cables. Does disabling the wireless mode turn off the RF output or just render the RF output unusable?
Thanks.
Dave
Solved! Go to Solution.
03-19-2009 07:12 PM
Please rate when applicable.
03-19-2009 03:11 AM
If you disable the wireless, your hub will not transmit or receive any wireless signals. Basically, your "wireless" hub will become a plain old hub.
03-19-2009 08:02 AM
Perfect. Thanks leolaohoo.
03-19-2009 07:12 PM
03-22-2009 02:24 PM
Thanks for the rating.
