forcing 802.11n client to a 5GHz radio
Mar 18th, 2009
I was wandering if there is a easy way to force clients to specific radios on a aironet 1250. For example, I like to make the 802.11n clients use the 5Ghz and the non 802.11n clients use the 2.5Ghz radio.
Scott Fella Wed, 03/18/2009 - 18:10
The only way you can do that now is on the client side. For 802.11N, you will bond two 20 MHz channels only on the 5GHz side. So clients that support 802.11N and the 5GHz should prefer the 5GHz than the 2.4GHz. But it will not stop client to use the 5GHz band which I think you are trying to accomplish.
You can always seperate the clients by ssid and only allow certain bands.... like create an 802.11N ssid for only 802.11N devices and a 802.11bg ssid for all others.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
