Call forward no answer timer
Mar 18th, 2009
DN 1000 called DN 2000, system-wide no-answer timer is 12 seconds, can I setup 3 seconds (~1 ring) for DN 2000 only? so if DN 2000 did not answer in 1 ring, the call will be forwarded to another DN
CCM v5
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 03/19/2009 - 02:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Guy,
***This can be changed on a per Device basis on the Phone configuration page> Directory Number Configuration> via No Answer Ring Duration = x number of seconds.
Hope this helps!
Rob
study_voip Thu, 03/19/2009 - 10:01
I got sense.
the CER solution is too bad, so will use this feature instead
flyingduckdk Thu, 08/20/2009 - 00:26
What UCM version are you running ?
on v.4.2(3) and 6.1 its in line configuration page about halfway down:
No Answer Ring Duration (seconds)
