Issue with DMVPN from 877W to 1841
I am trying to connect an 877W to an 1841 via DMVPN. An existing connection with 857W works fine using the same configuration (different tunnel IP etc)
When I debug the crypto engine I get ...
000097: Mar 19 14:26:39.058 Brisban: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
000098: Mar 19 14:26:39.062 Brisban: select crypto engine: ce_engine[3] does not accept the capabilities
Would anyone have an suggestions what could be causing this?
Some configs:
The 877W
crypto isakmp policy 99
authentication pre-share
crypto isakmp key secret address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10
crypto isakmp nat keepalive 20
crypto ipsec transform-set trans99 esp-des esp-md5-hmac comp-lzs
mode transport
crypto ipsec profile vpnprof
set transform-set trans99
Tunnel99
tunnel protection ipsec profile vpnprof
sh crypto engine configuration
crypto engine name: Virtual Private Network (VPN) Module
crypto engine type: hardware
State: Enabled
Product Name: Onboard-VPN
FW Version: 1
Time running: 2930 seconds
Compression: Yes
DES: Yes
3 DES: Yes
AES CBC: Yes (128,192,256)
AES CNTR: No
Maximum buffer length: 4096
Maximum DH index: 0020
Maximum SA index: 0020
Maximum Flow index: 0040
Maximum RSA key size: 0000
crypto lib version: 20.0.0
The 1841
mode transport
Tunnel99
tunel protection ipsec profile vpnprof
State: Enabled
HW Version: 1.0
Compression: Yes
DES: Yes
3 DES: Yes
AES CNTR: No
Maximum DH index: 0000
Maximum SA index: 0000
Maximum Flow index: 0300
crypto lib version: 19.0.0
crypto engine in slot: 0
platform: VPN hardware accelerator
Crypto Adjacency Counts:
Lock Count: 14086
Unlock Count: 14086
