Unity FailOver Replication Stopped working After password change
Mar 18th, 2009
  • Cisco Designated VIP,
    2017 IP Telephony
Guys,
I hvae a customer whose unity replication stopped working (5.0.1) after they changed the password on the servers.
All the changes made on the active unity server are not been replicated to the secondary server. Any ideas on what can be done to resolve this.
Jaime Valencia Thu, 03/19/2009 - 04:29
  • Cisco Employee,
  • Hall of Fame,
    2011
exactly what pwd was changed?
java
if this helps, please rate
Bradford Magnani Thu, 03/19/2009 - 06:30
  • Cisco Employee,
MSSQLServer and SQLServerAgent services should be running under a domain account if you're running failover. If that password was changed in AD but not on the services, you should see authentication errors in the application log and those two services will not be started.
Other than that, check in SQL Enterprise Manager under Replication and look for anything abnormal such as red x's on various jobs or roles.
Hope that helps,
Brad
