4948 45-48 ethernet interfaces are not up
Answered Question
Mar 19th, 2009
Good day.
I have a Cisco 4948. It's 48 ethernet ports and 4 fiber ports. Moreover, fiber ports have numbers 45-48 (the same numbers ethernet ports have).
There is a link between 4948 G1/45 and 2960 G0/1.
G1/45 on 4948 is:
inter g1/45
switchport access vlan 30
switchport mode access
end
G0/1 on 2960 is the same:
inter g1/45
end
It does not work. But if I use for example g1/43 port on 4948 with the same setting it works normally.
As I understand I should set the 45 ethernet port instead 45 fiber port as uplink. How to do this ?
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Vyacheslav,
it should be something like
int gi1/45
media-type rj45
I've used it on C7200 with NPE-G1
Hope to help
Giuseppe
Overall Rating: 4 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 03/19/2009 - 00:58
  • Hall of Fame,
    Founding Member
Hello Vyacheslav,
int gi1/45
media-type rj45
Hope to help
Giuseppe
