to find the switch port
Mar 19th, 2009
In a CM 4.1 environment how can I identify the exact switch port no., that a ip-phone is connected, without accessing any router or switch. Is there any way to find...?
Overall Rating: 4 (1 ratings)
Jaime Valencia Thu, 03/19/2009 - 04:27
if you mean from CUCM, there is no way to find it. CUCM does not have that info
if this helps, please rate
ullasmoopz Thu, 03/19/2009 - 06:22
thank you for your replay, java.
I mean from CUCM or ip-phone or by any means, but not by accessing any router or switch.
andylee100 Thu, 03/19/2009 - 07:48
This probably won't help, but on CM 6.1 with CER running, you can go to CER Administration/ERL Membership/Switch Ports, find a phone, then click View. It will show the Switch IP Address, Switch HostName and Port Name.
I have no idea if there is anything like this with CM 4.1 or if you have Cisco Emergency Response going.
mightyking Thu, 03/19/2009 - 08:04
OPen a browser and enter the IP Address of the phone then click enter. A new page will open, on the left side click on the "network" and scroll down to the bottom of the page and look for "Neighbor Port". That's the port where your phone is connected. You can also see the switch name and the IP Address and tons of other interesting info.
