1721 - TFTP Upgrade Issue
Mar 19th, 2009
hey all, i have a weird issue, the router shows that it has 32M of space but anytime we try to tftp an image, it complains that it has "(No space left on device)" we tried about 10 images but none work. i know there is a small trick somewhere. any help is appreciated. thanks a lot.
we also noticed a low voltage error message - am wondering if that is the root cause.
%Error: Low Programming Voltage Detected in System flash
%Error: System flash location 0x61FC004A - wrote 0x8358 , read 0xFFFF
HNL-1#dir
Directory of flash:/
No files in directory
33554428 bytes total (33554428 bytes free)
HNL-1#sh file sy
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
29688 27790 nvram rw nvram:
- - opaque rw null:
- - opaque ro xmodem:
- - opaque ro ymodem:
- - network rw tftp:
- - network rw snmp:
* 33554428 33554428 flash rw flash:
- - network rw rcp:
- - network rw ftp:
- - opaque ro cns:
HNL-1#
Address or name of remote host [10.0.0.200]?
Source filename [c1700-bk9no3r2sy7-mz.123-26.bin]? c1700-o3y-mz.122-8.TPC10c.bin
Destination filename [c1700-o3y-mz.122-8.TPC10c.bin]?
Accessing tftp://10.0.0.200/c1700-o3y-mz.122-8.TPC10c.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of flash: complete
Loading c1700-o3y-mz.122-8.TPC10c.bin from 10.0.0.200 (via FastEthernet0): !
%Error copying flash:c1700-o3y-mz.122-8.TPC10c.bin (No space left on device)
HNL-1#
Giuseppe Larosa Thu, 03/19/2009 - 01:05
  • Hall of Fame,
    Founding Member
Hello Robert,
this message appears multiple times
I'm afraid it is telling it is not able to really write or erase in this case on the flash a minimum voltage is needed and it says it is under the threshold.
It makes me think the flash can be defective or not well inserted.
I would power off ,open the device and check if it is well inserted
Hope to help
Giuseppe
Robert Ho Thu, 03/19/2009 - 02:00
yep, was hoping there was something else we can do. reseated the flash with no luck either. i guess this is heading to the recycling bin. thanks, robert.
Leo Laohoo Thu, 03/19/2009 - 03:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Errrr ... reseat? The 1720 series router's flash are all internal DIMM/SIMM chips. It's the 1760 that has a removable compact flash slot.
I hope I'm wrong here but I believe that the unit is about to die.
Robert Ho Thu, 03/19/2009 - 12:04
the 1760 does not have a compact flash slot. anyway, let's not get off topic.
