B Radios Seem to Reset
Mar 19th, 2009
I see the the following log entries quite regularly in the logs of all of my controllers. I am running 4.2 and 5.2 code. Does any one know why this is happening??
Thu Mar 19 05:27:32 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:14:6a:73:83:d0 Cause=Admin Configured
2 Thu Mar 19 05:27:32 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:14:6a:73:83:d0 Cause=Admin Configured
Leo Laohoo Thu, 03/19/2009 - 19:20
From the WLC, if you do the CLI command "sh ap eventlog ", do you see a line that goes like "%LWAPP-5-RLDP: RLDP stopped on slot 0." and then your radios go down/up?
If so, you need to set the AP's to detect whether you are operating in PoE or Injector. Go to Monitors -> All APs -> Choose the AP -> Advanced Tab and under Power Over Ethernet Settings choose Pre-Standard State if you are not using an Injector. If you are, choose Power Injector State -> Installed.
d-berlinski Fri, 03/20/2009 - 05:39
This is what I get from the CLI when this happens...
*Mar 20 07:18:59.994: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 20 07:19:00.003: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
The PoE is also checked as appropriate. If it was a PoE negotiation issue, wouldn't the 'A' radios reset also? This only happend for the 'B' radios.
dennischolmes Sat, 03/21/2009 - 13:21
Not always. Usually it's the other way around though. A radios usually drop first.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
